VCNet Post-Hoc Examples (with scikit-learn Classifier) ======================================================= In this page, we illustrate how to use :py:class:`PHVCNet` to generate counterfactuals for a shallow classifier. We take as an example a `scikit-learn` classifier. .. warning:: The classifier must be probabilistic. We use the same dataset as in the `VCNet` example: the Adult dataset. This time, we need to import two classes from our library: .. code-block:: python from vcnet import PHVCNet from vcnet import SKLearnClassifier :py:class:`PHVCNet` is the implementation of the counterfactual generator. :py:class:`SKLearnClassifier` is a wrapper for scikit-learn classifiers. It is configured through a dictionary specifying the classifier to use. Preparing the Dataset ----------------------- The data preparation is exactly the same as for VCNet. Please refer to the previous example. In principle, you create a :py:class:`DataCatalog` from the settings and prepare the data. .. code-block:: python dataset = DataCatalog(dataset_settings) dataset_settings = dataset.prepare_data(df) Preparing and Training the Classification Model ------------------------------------------------- Now, let's define the classification model and train it using the :py:class:`SKLearnClassifier` class. You can use the following code as a template: .. code-block:: python hp = { "dataset": dataset_settings, "classifier_params": { "skname": "RandomForestClassifier", "kwargs": { "n_estimators": 50, } } } train_loader = dataset.train_dataloader() test_loader = dataset.test_dataloader() classifier = SKLearnClassifier(hp) classifier.fit(dataset.df_train) In this code, the hyperparameters of the classifier are defined in `classifier_params`. It specifies the scikit-learn classifier class name and its *kwargs*. In this example, we use a random forest with 50 trees. Once the classifier has been defined through the hyperparameters passed to :py:class:`SKLearnClassifier`, the :py:func:`fit` function trains the classifier on the training dataset. At this stage, you have a trained classifier, but not yet the counterfactual generator. .. note:: We also wrapped an XGBoost classifier (:py:class:`XGBoostClassifier`) Training the Counterfactual Generator Model --------------------------------------------- The final step is to train the counterfactual generator model post-hoc. This process is very similar to the VCNet example, with the key difference being that creating an instance of :py:class:`PHVCNet` requires a trained classifier as a parameter. .. code-block:: python import lightning as L hp = { "dataset": dataset_settings, "classifier_params": hp['classifier_params'], "vcnet_params": { "lr": 1e-2, "epochs": 10, "lambda_KLD": 0.5, "lambda_BCE": 1, "latent_size": 16, "latent_size_share": 64, "mid_reduce_size": 32 } } # Define the post-hoc VCNet model vcnet = PHVCNet(hp, classifier) # Finally, fit it using a Lightning module trainer = L.Trainer(max_epochs=hp['vcnet_params']['epochs']) trainer.fit(model=vcnet, train_dataloaders=train_loader) Once your counterfactual generation model has been trained, it can be used in the same way as other VCNet models (see the other examples).
